Preemptive ICM and Coil replacement
Old May 23, 2023 | 11:02 PM
dburgjohn's Avatar
dburgjohn
Default Preemptive ICM and Coil replacement
reading misc posts let me through several talking about failing ignition modules and coils. at 92k should this be done preemptive repair to avoid or just wait until it acts up?
Old May 24, 2023 | 11:20 AM
pedricd's Avatar
pedricd
I was one of the ones with this problem.
I would suggest leaving it alone. If you are worried maybe pick up a spare ICM but they aren’t exactly cheap…coils are… I probably should have done the coil when I replaced everything else (opti, wires, plugs) but my coil wasn’t the problem anyway.
It appears my ICM may have not been OEM so that could be reason for failure, plus almost completely gone heat sink compound.
If it was me, and in retrospect, I would get some high quality heat sink compound, remove and clean the ICM/heat sink, reapply with the good compound and reinstall. I suspect the compound dries out and or oozes out over time and may contribute to failures.
Old May 24, 2023 | 01:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^That^
You won't get aftermarket components that are as good as OEM components....so if the OEM is working, keep it working.
Old May 24, 2023 | 02:19 PM
KrK96Vette's Avatar
KrK96Vette
I bought my 96 with 80 grand on the dial. First thing I did was replace the 27 year old ignition parts, sensors and switches that feeds the ECM information. If I could not find AC Delco or Delphi, I went with NAPA which is Standard Automotive brand and good quality most of the time. Because I'm running NGK plugs, I went with their top line coil and an AC Delco module. On a 96, you need to stick to Delco on the module, otherwise you'll get a CEL. I found this out by replacing the module with NGK as well and got the CEL light. Plenty of threads on that one. I feel better with all brand new parts versus parts with over 80 grand and 27 years old that feeds information to the ECM. If you have the money? I think it's a good idea. Especially if you're tuning your car for more torque and horsepower.
Old May 24, 2023 | 04:40 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
None of those parts "feed information to the ECM".
Old May 24, 2023 | 04:50 PM
KrK96Vette's Avatar
KrK96Vette
Go argue platitudes with yourself, not wasting anymore time with you. Did plenty of that years ago in the Crossfire forum. Open a TunerCat or Jet DST. The ECM controls just about everything on a 95-96 including timing.
Old May 24, 2023 | 05:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sure thing, bud!....then you do this....
Good thing you didn't waste your time arguing!
I don't need to open a TunerCat or a Jet DST: I already know how the ignition works.
IDK who you are, since you changed usernames, but based on what you've just posted, I fully believe that you: "Did plenty of that years ago in the Crossfire forum", because you were wrong then, too.
Anyway, you're absolutely right that "the ECM controls just about everything on a 95-96 including timing". That's not what you said in your first post though. The ECM does control timing...however, YOU said,
....replace the 27 year old ignition parts, sensors and switches that feeds the ECM information..... I feel better with all brand new parts versus parts with over 80 grand and 27 years old that feeds information to the ECM.
None of the parts that you listed; ICM, coil, spark plugs....feed information to the ECM. I didn't "argue platitudes"...I simply corrected wrong information. Sorry that you can't tolerate that.
And hey....it's GREAT doing maintenance that helps you "Feel better"...but that is treating a psychological issue....not an actual one. My LT1 is 31 years old and has 206k on it. I've never changed the ICM or the coil. What am I missing??
Old May 24, 2023 | 08:30 PM
KrK96Vette's Avatar
KrK96Vette
Originally Posted by IHBD
Fixed it for you.
My thought on the matter of prophylactic replacing of currently functioning OEM parts: "A good-running, trouble-free car is like a hard-on. If you want it to continue, don't F with it."
Good for you now go pound another case of BUD LIGHT! 😆
Old May 24, 2023 | 11:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Attacking two veteran, high contributing forum members? Already? You're off to a rough start here.
You could learn-a-thing...but maybe you should go back to the CFI forums, instead. This one might not be a great fit.
Old May 25, 2023 | 01:22 AM
KrK96Vette's Avatar
KrK96Vette
Aww, did your feelers get hurt there buddy boy?? It's all good man, continue to rule your world. Meanwhile, I'll be moving onward. See you in the next one I comment in since you like to follow me around. A difference in opinion was never your strong suit.
Old May 25, 2023 | 09:29 AM
pedricd's Avatar
pedricd
Umm…wow…k…huh?
Sorry OP! Hopefully you gleaned some solid advice through the BS…. Let us know if you have follow on questions.
Old May 25, 2023 | 09:42 AM
dburgjohn's Avatar
dburgjohn
Umm…wow…k…huh?
The world is an interesting place.
I am interested in the thermal paste between the cylinder head and heat sink as well as between the ICM and heat sink. Still trying to processes the "hot headed" LT1 cylinder head being a place to shed excess thermal energy.
Old May 25, 2023 | 10:46 AM
pedricd's Avatar
pedricd
Thermal paste does not go between the coil/ICM mount and the head. I put it in between the ICM and the heat sink (a separate piece of metal) and the heat sink and the coil mount. Not sure if the latter helps much but there was some residue there when I took it apart (directions didn’t ask for this I don’t believe). I figure that adds the coil mount to the overall “sink”.
If having it attached to the head was a problem they would fail a lot more frequently. I think the head, while hot, may keep the ICM cooler than if it was mounted to somewhere else or “free floating” somewhere…and you’d have to find a way to mount it on a giant heat sink (which the head is). Since there is no thermal paste between the head and mount the transfer isn’t ideal either…but still I think it was all designed this way and I wouldn’t worry about it.
critical is the paste between the ICM and the small heat sink. Putting fresh stuff there I think is a great preventative.
Old May 25, 2023 | 10:50 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^True^^
Krk, Ha ha ha...you poor thing. No feelings hurt here, but I'll address your continued BFS:
Ah...I've been a member here since ~2004. You? Less than a year. You called me out from posts that I made on the CFI forum...from 20 years ago!? Wow.... IDK who you are, and don't really care since most of your posts are dog ****, but who's "following" who?
And there is where you go off the rails; you can't decipher the difference between opinion, and fact. That's unfortunate for you. For example, in this thread, it's your opinion that you should change electrical components, because it helps you feel better. That's an opinion and you're entirely welcome to that opinion.
On the other hand, you stated that the ICM and ignition coil are parts that "feed the ECM information"....they do not, and that is not opinion, that is fact. I corrected that fact, and you obviously can not handle that correction, which is unfortunate.
Awesome. Best idea I've heard from you, yet. As you were.
Old May 25, 2023 | 12:23 PM
KrK96Vette's Avatar
KrK96Vette
^True^^
Dude, you get so upset over the stupidest ****. I would bet most here regardless of time being members see right through your bs. You indulge and engage and I would even say pride yourself with trying to correct people when it's really not important or needed. This empowers your ego and it stands out in just about every thread your name is attached to. I added some information to the ops post giving him some ideas he could do. You like to analyze each word and phrase of a persons comment and then criticize them with accusations. It makes you "feel good" about yourself. Just like it makes me "feel better" about having some new parts. Anyways bud, you have a great day. I know I will. 🤟😎
Old May 25, 2023 | 12:25 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep, I do all that. Facts matter. BTW; where did I "criticize" in my first response?
As you were, my man. AMF.
To Preemptive ICM and Coil replacement
