oil temp sensor question
Old May 27, 2023 | 07:06 PM
sturmmorser2000's Avatar
sturmmorser2000
Default oil temp sensor question
Im putting in a new one do i use rtv on the threads or can i use teflon paste?
Old May 28, 2023 | 07:54 AM
jmeyer58's Avatar
jmeyer58
My replacement came with Teflon already applied so that’s what I would recommend
Old May 28, 2023 | 08:19 AM
detroitrust's Avatar
detroitrust
I asked in another section but no response. Are you replacing because of failure or just prevent maintenance? I have the manifold off and I read somewhere, just replace while there. Car has 17k miles (93 lt1).
I can get a part that claims to be AC Delco for $40.
Old May 28, 2023 | 09:56 AM
jmeyer58's Avatar
jmeyer58
I replaced because I’m a clod and broke the connector housing when I pulled the motor. 🤣🤣😂. Are you sure you’re replacing the temp sensor, it is located on the side of the block just above the oil filter. The oil pressure switch is located just behind the intake manifold. If you have the intake off, I could see replacing the oil pressure switch to avoid an oil leak 👍.
Old May 28, 2023 | 09:57 AM
jmeyer58's Avatar
jmeyer58
Teflon is still my choice for the pressure switch
Old May 28, 2023 | 01:23 PM
Aardwolf's Avatar
Aardwolf
Most of these type are recommended not to use additional sealer because the sensor grounds through the body of itself unless it's a type with more wires and has a ground wire. Most come coated too and in practice I haven't noticed problems with sealants. The top of the thread is still bare.
Old May 28, 2023 | 06:07 PM
sturmmorser2000
Its the temp sensor above the oil filter. I broke the blade on my old one.
Old May 29, 2023 | 10:18 AM
yakmastermax's Avatar
yakmastermax
Curious about what part of used to replace the oil temperature sensor. I installed a brand new oil temperature sensor in my 1991 and the gauge still doesn't read correctly.
To oil temp sensor question
