C4 88 Crank-no start (fuel problem)
Old May 30, 2023 | 09:50 AM
Torishimo's Avatar
Torishimo
Cruising
Default C4 88 Crank-no start (fuel problem)
Hi guys, my first post here!
(also not native eng. speaker so I beg your pardon : P )
Long story short. I was driving no problems for some time. Pulled to a prking lot, next day crank but no fire.
All fuses checked, fuel realy clicking, Shrader valve on fuel rail was bleading fuel hard for a day, I cloget him to not cause fire. Next day check he is still bleading.
I was cranking couple times until battery was dead while looking for clues.
Today I removed gas cap (non oroginal I bought it weeks ago), Plug battery and she started... for a second and stalled. Shrader valve stoped leaking.
To be honest I dont know what it could be. Removing gas cap and lowering the pressure make engine start? I dont understand logic behind it, may be one of you guys can help? Was it a clue or an anomaly?
Old May 30, 2023 | 10:54 AM
My84isMeanToMe's Avatar
My84isMeanToMe
It's possible your fuel pump could be going bad. Try to hook up a gauge to the fuel rail to check your fuel pressure. You could probably rent one from an Autozone. Also wouldn't hurt to change the fuel filter while your at it. It's located on the passenger side of the vehicle up by the front tire.
Edit: I'd also recommend putting some type of injector cleaner in your gas
Old May 30, 2023 | 10:59 AM
Torishimo's Avatar
Torishimo
Cruising
Hey, thanks for fast answer!
pressure gauge is comming tomorrow or in 2 days, so I will check it as fast as I can. Sadly, no autozone here xD
I was looking for the fuel filter, could not find it, maybe I have to jack the car and then search a bit deeper for it.
Old May 30, 2023 | 11:08 AM
My84isMeanToMe
Fuel filter location
Old May 30, 2023 | 02:39 PM
Torishimo's Avatar
Torishimo
Cruising
Huge thanks man, now I know where to look at. Since I am on parking lot, I wonder how much fuel will come out. maybe I will buy a metal pen or smth
Old May 31, 2023 | 08:43 AM
Torishimo's Avatar
Torishimo
Cruising
Hmm I am about to take off fuel filter, but which should I buy? do we have any demensions for it? Or maybe you guys know a good fuel filter brand? (I checked out bosh, and those Made in Tunisia have really bad reputation) :/
Old May 31, 2023 | 08:52 AM
My84isMeanToMe
I bought a premium guard filter and I haven't had any problems, as for the fit you would just have to look it up for your year of car
Old May 31, 2023 | 09:24 AM
Torishimo's Avatar
Torishimo
Cruising
Ah, Its harder to find good fuel filter than I was expecting. Do you know some good brands that wont fail me?
Old Jun 19, 2023 | 01:12 PM
Torishimo's Avatar
Torishimo
Cruising
Ok guys, In the end It is fuel pump. Pump its barely running and it not suffice for car to start.
Do you know specs of fuel pump? I definetly dont want to buy Delphini chinesee one.
To C4 88 Crank-no start (fuel problem)
