BRAKE light stays on
Old May 30, 2023 | 09:47 PM
AndresWTRMLN's Avatar
AndresWTRMLN
Default BRAKE light stays on
Today I went out for a drive and on my way back I got cut off and I braked hard luckily not hitting the idiot that cut me off, I noticed on my instrument cluster that the BRAKE light was on and not going away I also noticed that my brakes were softer and I needed to press further down in order to brake, thankfully I got home without anymore issues, I turned the Vette off and then turned it back on in order to see if the light will go away but it doesn't, I also applied the E-Brake then disengaged it to see if that would make it go away but it didn't, any ideas on what my problem could be?
(For anyone wondering I won't be using it until the problem is fixed)
1993 Corvette LT1 Automatic
Old May 30, 2023 | 11:45 PM
jv9999's Avatar
jv9999
Most likely you sprung a leak. There is a swtich in the master cylinder that will turn the light on if either the front or rear loses pressure. If you open it, one side is probably low or empty.
Old May 31, 2023 | 12:33 AM
KMS88Cal#16's Avatar
KMS88Cal#16
I would check your brake fluid. There’s a low brake fluid sensor that could have been activated when you hit the brakes. Add fluid if needed. This happened on my 93.
Old Jun 5, 2023 | 07:33 PM
64Scout's Avatar
64Scout
If the light is on and the pedal is soft, you have a leak somewhere.
Old Jun 5, 2023 | 07:59 PM
AndresWTRMLN
I checked the fluid level and it's perfect
Old Jun 5, 2023 | 08:02 PM
AndresWTRMLN
I turned the Vette on and I did hear some suction from the brake booster area I never heard it before so I'm going to remove it and start there I did check the brake lines and none were leaking
Old Jun 5, 2023 | 08:05 PM
AndresWTRMLN
I turned the Vette on and I did hear some suction next to the brake booster I never heard it before so that's suspect #1, thanks for the tip
To BRAKE light stays on
