drivers headlight issue
Old May 31, 2023 | 04:06 PM
Rdboon's Avatar
Rdboon
Default drivers headlight issue
ok i just replaced the driver headlight motor...old one was coming apart inside and the gear was smooth. with a test light i can test it at the plug and one side is hot, but when i flip the switch i get no hot. my understanding is the polarity changes to open/close the motor. i am suspect that the module is bad because i get a hot wire when on, but nothing when turned off. hot wires to the module are good. any suggestions?
