Turn signal problem, please help!
Old Jun 1, 2023 | 04:17 PM
My84isMeanToMe's Avatar
My84isMeanToMe
Default Turn signal problem, please help!
I have a 84 vette and my right turn signal doesn't work. Whenever I go to turn right the light on the dash stays on and and the lights outside turn on but don't blink. But if I have the running lights and headlights on they don't turn on at all on the outside and the right turn signal indicator just stays on the dash until I turn the lights off. I have all new correct bulbs, but it was doing this before I installed them aswell so idk
Old Jun 1, 2023 | 10:31 PM
Lord Gray Hair's Avatar
Lord Gray Hair
I would have thought it was a bulb but you stated they are replaced
Turn signal relay?
I have had this work twice before so you may try it it wont cost anything
Engage the emergency flasher for at least 30 seconds at least walk around the car and see if they are flashing as they should
Shut it off Then try the turn signals again
If they work for second or two then quit it's probably the flasher
Good luck
Old Jun 2, 2023 | 10:48 AM
Vets-Vet's Avatar
Vets-Vet
I am not much help, but maybe tell us if the hazards are working ?? There is a ground on the frame near the coolant reservoir, you might check that.
Old Jun 2, 2023 | 12:00 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
You might have 40 years of petrified grease in your sockets.
That all needs to come out. I used a very thin-bladed screwdriver to dig it out of all of those grooves.
Or replace the sockets. They're inexpensive and available locally. I replaced a lot of mine after deciding it was more efficient and they get old and crunchy anyway over the years, so why not...
A lot of times you cant get a full twist on the bulb if that old crud isn't removed.
Old Jun 2, 2023 | 02:41 PM
My84isMeanToMe
My hazards do work completely when turned on
Old Jun 2, 2023 | 05:33 PM
Vets-Vet's Avatar
Vets-Vet
It is possible the hazard and turn signal flashers are the same part number if you want to try and swap them, I would check the part numbers on them before doing so but most sites that supply parts list them both as the same number. My FSM, parts and wiring diagrams are for an 87. I am not sure about the 84's locations, I am "guessing" one (hazard) is behind the drivers information panel (center stack) and the other (turn signal) is near the ECM on passenger side but again, I don't have an 84.
Old Jun 3, 2023 | 12:41 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
you probably have a bad socket somewhere. You'll have to wiggle them all while the signal is on and hope they blink when you do it. If it was the flasher, the other side wouldn't work either
Old Jun 3, 2023 | 04:25 PM
No83's Avatar
No83
Bad grounds exhibit this symptom. Wouldn’t hurt to clean your grounds, there is one near each headlight on the frame.
Old Jun 4, 2023 | 07:18 AM
LiveWire1's Avatar
LiveWire1
The turn signal flasher operates by using the heat generated by the light bulb amps flowing through it, to bend a bi-metallic switch contact. If there's no amps, there's no heat. If there's no heat, then there's no on/off switching. I'd look at the bulbs themselves on the right side. I'm wondering if being 1157's, they could be turned in the socket, so that you're switching on the running light filaments instead of the turn indicator filaments. When you have the hazard light switch on, are the right bulbs as bright as the left bulbs? One other possible solution may be to replace the mechanical bi-metal flasher relay with a solid-state flasher.
Old Jun 4, 2023 | 10:40 AM
Bill Chase's Avatar
Bill Chase
look for a busted, or missing ground strap in one of the front turn signal/running light bulbs. literally just went through this exact same situation with my 91 c4.
Old Jun 4, 2023 | 10:42 AM
Bill Chase's Avatar
Bill Chase
and a broken ground strap that is not, or has intermittent contact with the base of the bulb will cause the exact same scenario. a quick check to see if it is the culprit is to check the hazards. if the dash indicators blink and you get all the lights flashing. you most likely have a bad bulb socket in the front of the car. there ared subtle year to year differences, but basically all year c4 are wired the same.
Old Jun 4, 2023 | 11:00 AM
Vets-Vet's Avatar
Vets-Vet
""But if I have the running lights and headlights on they don't turn on at all on the outside and the right turn signal indicator just stays on the dash until I turn the lights off"".....
Does this mean if you turn only the headlights on the turn signal bulb will light ??
Old Jun 4, 2023 | 12:18 PM
mike1111's Avatar
mike1111
I had to change turn signal switch and brake light switch to fix turn signal problem
Old Jun 4, 2023 | 01:10 PM
Bill Chase's Avatar
Bill Chase
check all bulbs, check all power and ground in every socket, even the side markers. then check the flasher relay, helps to have the fsm for your year car. subtle year to year wiring differences.
To Turn signal problem, please help!
