Question for the auto transmission experts
I'd like to find a complete input drum assembly already assembled with the input shaft. The only one our mechanic is familiar with is the Sonnax but they seem to be nationally backordered with no ETA. I'm not just going to let the car sit indefinitely waiting on a part so I need to make a decision to just go back to stock parts or look at another assembly.
I know there is a group that will swear to go back to stock (no matter what we are talking about). Not really interested in hearing that, thank you. I know that's an option.
I would like to hear from someone with transmission building experience that has used an upgraded input drum assembly that they have had good experience with. If its a little more expensive than the Sonnax, it still may be worth it simply because its in stock.
Thanks,
Toby AKA Tobtech
Stock drum with steel pistons, BW 29 element sprag, Tan overruns, red forwards and red 3/4 frictions work well.
I usually remove the wave in the 3-4, use full thickness steels, thin snap ring and 7 frictions.
Keep the forwards about .040 and the 3-4’s about .050. Be sure the return springs are fresh if you run them tight.
Just my 2 cents.
Dana has a good reputation for supplying parts that work and complete transmissions.
