Oil pump shaft coupler needed?
Old Jun 14, 2023 | 12:43 PM
cds1's Avatar
cds1
Default Oil pump shaft coupler needed?
When I rebuilt the LT1 in my '95 last year, I replaced the oil pump. Both the original and replacement (Melling M155) came with a plastic shaft coupler (arrow in image). The replacement coupler broke and I just cleaned the pieces out of the pick up screen. Before I replace it, what purpose does it serve? It seems to align the blade and slot of the shaft to reduce off center twisting forces... but I'm not sure. I'm a bit hesitant to replace it since I see no reason it won't break again, and in a way that could be detrimental to the engine. I'd rather not disturb the assembly since it ran over 1 year/1500 miles w/o a problem.
The engine was pulled for leaking timing cover seals... nothing related to oiling.
Old Jun 14, 2023 | 12:51 PM
Vette5311's Avatar
Vette5311
Throw it away and get one with a steel coupler that is pinned.
Old Jun 14, 2023 | 01:00 PM
cds1's Avatar
cds1
Thank you!
Something like this?
Old Jun 14, 2023 | 01:39 PM
Vette5311's Avatar
Vette5311
Yep, that’s it. The one with the reduced diameter is for strokers, they make a straight shank one also. Either is ok.
Old Jun 14, 2023 | 02:56 PM
cds1's Avatar
cds1
Thanks a lot.
To Oil pump shaft coupler needed?
