hood allignment problem
Old Jan 18, 2003 | 06:00 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default hood allignment problem
i have the hood on it looks good back where the hood meets the doors but the passanger side at the bumper looks kind of back to far off is there an adjustment on the bumper fascia or just on the hood alone :cheers:
Old Jan 18, 2003 | 08:22 PM
Brian Witt's Avatar
Brian Witt
Default Re: hood allignment problem (CORKVETTE1)
I've never tried it before but if it is the bumper that needs adjustment and not the hood... The front fascia can be adjusted through a hole in the center top of the impact bar by inserting a bar into the hole and prying outward (to increase gap between hood and fascia) or inward (to reduce gap). Like I say, I've never tried it, that's straight out of a service manual. There are shim plates on the front of the crossbar tie member which can added to or subtracted from. (The crossbar tie member is the aluminum or steel brace across the front that connects to the front of the right and left frame rails) The bolts attaching the front fascia to the crossbar tie member I believe have the nuts tightened from the engine side of the crossbar tie member. If these were to come loose the shims could vibrate out of place since they simply slide in an out with the bolts going through U shaped slots rather than holes. Someone who has worked with a front bumper could tell you more. I do not know what all is involved with changing the shims.
[Modified by Brian Witt, 1:29 AM 1/19/2003]
Old Jan 18, 2003 | 09:38 PM
buzzbomb's Avatar
buzzbomb
Default Re: hood allignment problem (Brian Witt)
Where can you get the shims at?
Old Jan 18, 2003 | 09:42 PM
Brian Witt's Avatar
Brian Witt
Default Re: hood allignment problem (buzzbomb)
dealership, I assume
To hood allignment problem
