95 ride control rear actuator access
Old Jan 18, 2003 | 06:35 PM
Yellow95's Avatar
Yellow95
Default 95 ride control rear actuator access
Before I dig in tomorrow, can you get at the rear actuators to check them without removing the shock?
The service light is on (again) and fronts look good. Tomorrow I will pull the codes and start disassembly/beer drinking, if required. :cheers:
[Modified by Yellow95, 5:36 PM 1/18/2003]
Old Jan 18, 2003 | 08:03 PM
2012 coupe's Avatar
2012 coupe
Default Re: 95 ride control rear actuator access (Yellow95)
Nope. Jack up the rear and remove a tire. There are two bolts that hold the top of the shock onto the frame. Remove both of these along with the bottom bolt and ease the shock out. Then you can check the actuator. If disconnecting it, make sure it does not slip back into the frame.
:flag
Old Jan 19, 2003 | 12:08 AM
kittmaster's Avatar
kittmaster
Default Re: 95 ride control rear actuator access (Danah92LT-1)
why take the shock off? You can just undo two bolts, slide shock towards the outer car body, and remove actuator. Hope it works out for you.
Kitt
To 95 ride control rear actuator access
