Carbs
Old Jun 26, 2023 | 03:24 PM
Joerob10's Avatar
Joerob10
1st Gear
Default Carbs
I have an 84 corvette with a dual plane with Holley carbs but only the front carb is getting fuel to it I checked the fuel rail and it is not clogged
Old Jun 26, 2023 | 08:36 PM
wilcar's Avatar
wilcar
Are you sure the rear carb fuel circuit is not blocked off on purpose?? Could have been running pig rich so someone disconnected the linkage or blocked the fuel circuit on purpose. Better find someone that knows dual carb set ups that can properly tune a dual carb set up. Good luck!
Old Jun 26, 2023 | 09:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Check to ensure that the rear float's needle and seat isn't stuck closed. Then, find someone that knows dual carb set ups that can properly tune a dual carb set up. Good luck!
Old Jun 27, 2023 | 12:52 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
To Carbs
