Corvette C4 idle issue
Old Jul 3, 2023 | 06:09 PM
TheArbiter's Avatar
TheArbiter
3rd Gear
Default Corvette C4 idle issue
For some reason my corvette lopes and nearly dies multiple times(before finally dying completely) and holding down the brake pedal makes it stop the issue completely, please help
Old Jul 3, 2023 | 07:13 PM
s carter's Avatar
s carter
Step 1 with engine off remove air tube, get a rag and Carburetor cleaner open the throttle wide open spray carburetor in the bore and on the Rag. Wipe the throttle body bore and plates clean, reassemble and road test.
Most of the time this does the job, if not then 02 sensors need a look at as well as the Minimum Idle settings, also mention year, transmission and any modifications in future
