Fuel feed from cold start fitting for nitrous?
Old Jan 19, 2003 | 02:27 PM
Phobos84's Avatar
Phobos84
Default Fuel feed from cold start fitting for nitrous?
I have this idea. I am using an older style fuel rail with the cold start injector on a L-98 TPI with a newer style ECU that dosn't use cold start. So I drilled the fitting a little and put a flared fitting on it to run the fuel to the solenoid for the nitrous system. The fitting is the same kind that is used for the test port. Can anyone think of any problems doing it this way? I want to leave the test port open for a fuel pressure gage. Anyone have any input?
Old Jan 19, 2003 | 07:38 PM
scorp508's Avatar
scorp508
I don't really see any reason not to think this would work. I would just make sure that you make the fitting on the fual rail large enough. :)
Old Jan 19, 2003 | 10:31 PM
Phobos84's Avatar
Phobos84
Default Re: (scorp508)
It's bigger then the metal tubing that comes with the system. I don't think thats a problem. I did have to drill it out a little. Then I JB welded it to stop any leaks.
To Fuel feed from cold start fitting for nitrous?
