ZF Tranny Noise
Old Jan 19, 2003 | 08:35 PM
mac383's Avatar
mac383
Default ZF Tranny Noise
I have a ZF traany out of a 92 that whines in the first 4 gears. I'm to the point where I want to crack it open, I understand that ZF now sells parts to rebuild these units, has anyone out there attempted this our know where I could get a manual? Thanks
Old Jan 19, 2003 | 09:11 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Default Re: ZF Tranny Noise (mac383)
check http://www.zfdoc.com
Email Bill, the owner, can help you out one way or another.
Ed
Old Jan 19, 2003 | 09:54 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: ZF Tranny Noise (fastzr1)
In what do you have it installed???
[edit] Oh, I see in an 89. So you used the dual mass flywheel.
Does it whine real bad? All ZF-6's I've seen had a slight whine because of the way the gears are cut.
[Modified by Twin_Turbo, 8:56 PM 1/19/2003]
Old Jan 19, 2003 | 10:22 PM
nisstek's Avatar
nisstek
Default Re: ZF Tranny Noise (Twin_Turbo)
The ZF in my LT4 car also whines. 1st is loudest. Gradually diminshes until it cannot be heard in 4th. Returns slightly in 5th. I would associate it more to a high pitched gear whine as opposed to bearing (aka front counter or input shaft bearing) noise. My experience with bearing noises has them making a lower pitched noise. I dont know anyone locally who has a Vette ZF to compare it to. Would I be safe in saying that as long as its quieter than a Winston Cup road track car trans, its OK???? Is this the same symptoms that your ZF has, MAC383?
Old Jan 20, 2003 | 08:10 AM
Rick93Z07's Avatar
Rick93Z07
Default Re: ZF Tranny Noise (nisstek)
Cripe! A Winston car has straight cut race gears and their whine can be heard for miles...much like a "60's garbage truck with 500K miles on it. My trans does not whine noticeably when the clutch pedal is out. It is barely audible. Standard Gear is the primary distributor for ZF parts. They will offer you the deepest discount, if you pass yourself off as a transmission shop or Jobber.
I assume you've changed your fluid recently?? Fresh fluid greatly reduces gear whine in healthy transmissions. It also minimizes gear, bearing, bearing surface and shaft wear that "causes" chronic noise and necessitates rebuild.
[Modified by Rick93Z07, 8:16 AM 1/20/2003]
Old Jan 21, 2003 | 08:13 AM
Polar LT4's Avatar
Polar LT4
Default Re: ZF Tranny Noise (Rick93Z07)
How do you pass yourself off as a tranny shop or jobber? Standard gear would not sell to me!
To ZF Tranny Noise
