High idle issue
Old Jul 25, 2023 | 11:22 AM
MSREP9285's Avatar
MSREP9285
4th Gear
Default High idle issue
I have an 88 that I have a built 400 in. I recently installed the tpis mini ram with 40lb injectors. It has a DUI street/strip distributor. New iac that has been reset using the obd port method. The prom has been adjusted by Howell efi. I set the timing to 8° btdc where they suggested it to be and idles at 7-800. The problem is when I reconnect the esc wire it runs at 19-2000 rpm even after warming up. I have sprayed enough starting fluid at it looking for a vacuum leak to blow myself up and not even a slight change. Please tell me someone knows what the problem is or can get me in the right direction. Also do you think it could be a vacuum leak since it runs fine with out the esc. Thank you
