Replace Headers
Old Aug 7, 2023 | 05:38 PM
Riverman1031's Avatar
Riverman1031
5th Gear
Default Replace Headers
90 C4 L98. What am I going to need to do to remove and replace the header on the right bank?
Old Aug 7, 2023 | 07:31 PM
Incorvettei's Avatar
Incorvettei
Did mine without removing anything but the dipstick tube in the right side. Of course I had it off the ground about 4 feet. Easy to do if you have access to a lift
Old Aug 8, 2023 | 11:42 AM
Riverman1031
5th Gear
I wish I had access to a lift. I was just worried about that last bolt on the right bank. Not much room to work there and was worried about lifting the engine several inches to reach it. Did you reach that bolt from below?
Old Aug 8, 2023 | 12:11 PM
yakmastermax's Avatar
yakmastermax
On my 1989 and on my 1991 the rearmost passenger right side header to cylinder head bolt I removed with a medium length flat box end wrench coming from below. Flat box end wrench, no offset angle.
The first time I tried a ratchet and socket and ended up cross threading the hole due to the small clearance.
Had to chase the threads with the head in the car.
Old Aug 9, 2023 | 10:32 AM
Riverman1031
5th Gear
Thank you. Really do appreciate the information. Stupid me didn't think about getting it from below. Everything else I figured I could resolve, I was just worried about that one bolt.
To Replace Headers
