No Start
Old Aug 9, 2023 | 10:21 AM
fooda2's Avatar
fooda2
Default No Start
Not sure where this went so here goes 89 no start fuel pressure 40 on cranking spark ,I put new injectors in , so had it running but not being smart I disconnected the one terminal on battery thinking the old way of checking alternator is what I do yes dumb *** move now no start …..please help Iam lost btw new ECM
Old Aug 9, 2023 | 11:04 AM
Tunedport90's Avatar
Tunedport90
Disconnecting the battery is a good way to have the alternator spike and destroy electronics . So your just missing injector pulse ?
Old Aug 9, 2023 | 11:11 AM
fooda2's Avatar
fooda2
Default No start
I believe there is pulse I measured each injector reading 13.9 all of them but as you asked Iam not thinking it’s pulsing fuel plug looked dry
Old Aug 9, 2023 | 11:19 AM
fooda2's Avatar
fooda2
also power to leads test light I used for that
Old Aug 9, 2023 | 11:34 AM
Tunedport90
Use a noid light, you could have a bad icm or could even be a unrelated vats issue.
Old Aug 9, 2023 | 12:43 PM
fooda2's Avatar
fooda2
ICM? The ECM I replaced I’ve used noid light very weak light though
Old Aug 9, 2023 | 01:38 PM
Tunedport90
Does the noid get brighter with all injectors unplugged. If noid is blinking the icm (ignition control module) is probably fine. Are these the newer D3 injectors ohm seems kinda low
Old Aug 9, 2023 | 02:00 PM
fooda2's Avatar
fooda2
Default No start
Not D5 but I did not try with all injectors unplugged I try that now , is there a hidden fuse Iam not seeing ?
Old Aug 9, 2023 | 02:18 PM
Tunedport90
I don’t know what D5 are or what fuse your referring to.
Old Aug 9, 2023 | 02:40 PM
fooda2's Avatar
fooda2
Default No start
Sorry I meant D3 injectors you mentioned, Iam thinking these injectors are not getting pulse from ECM to operate noid light is full but just steady
Old Aug 9, 2023 | 02:51 PM
Tunedport90
back to icm if not blinking the noid, bad ecm ground or vats. Unless the reference line from icm to ecm purple/white is damaged or unplugged.
Old Aug 9, 2023 | 02:55 PM
fooda2's Avatar
fooda2
Default No start
Ok that puts me in better position I will check wires , ground , vats I’ll wing it it turns over but who knows
Old Aug 9, 2023 | 02:57 PM
Tunedport90
I’d guess a icm got damaged from voltage spike but just a guess.
Old Aug 9, 2023 | 03:24 PM
fooda2's Avatar
fooda2
Default No start
I don’t believe these injectors are spraying fuel plugs bone dry.,,,I grounded ECM case to negative side of battery…no luck
Old Aug 9, 2023 | 03:26 PM
fooda2's Avatar
fooda2
Default No start
Wouldn’t I have no spark if so ?
Old Aug 9, 2023 | 09:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
On these injectors the noid light will be very dim…I just use a LED test light connected to battery positive…these injectors usually draw less than 1 amp.
Old Aug 9, 2023 | 09:41 PM
fooda2's Avatar
fooda2
Default No start
Ok thank you for the info the noid light is very dim , clamp to positive side of battery and go to each terminal on injector wire?
To No Start
Old Aug 9, 2023 | 09:51 PM
C5 Diag's Avatar
C5 Diag
These injectors are “ground side switched” meaning the PCM supplies a ground to make the injectors work…that is why we hook the test light to battery positive !!
Old Aug 9, 2023 | 10:00 PM
fooda2's Avatar
fooda2
Default No start
Ok understand the ECM supplies ground to complete circuit correct so where am the suppling the positive?
Old Aug 9, 2023 | 10:23 PM
C5 Diag's Avatar
C5 Diag
You connect the alligator clip of the test light to battery POSITIVE or B+ of the alternator…when the test light finds a ground it will light.
