Backfire during idle
Old Aug 16, 2023 | 12:35 AM
Cameron14733's Avatar
Cameron14733
Default Backfire during idle
I’ve had an issue with my 1989 corvette backfiring at idle ever since I replaced my fuel injectors does anyone know what’s wrong? I do need a new EGR sensor could that cause it? I checked all vacuum lines and there all good and I don’t have a check engine light.
Old Aug 16, 2023 | 11:42 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Have you checked where your timing is set and your ignition system? New fuel injectors are best served if you do a full tune up in conjunction.
Old Aug 16, 2023 | 12:06 PM
Cameron14733
yes my timing is on point. However I’m currently running a header dump until I get the money for a full exhaust could that be causing it ?
Old Aug 20, 2023 | 04:09 PM
Cameron14733
full tune up is done already new spark plugs and injectors
To Backfire during idle
