View Poll Results: Replace both heads or just the damaged one ?
One side
22.22%
Both sides
77.78%
Voters: 9. You may not vote on this poll
Cylinder head replacement
Old Aug 18, 2023 | 08:48 PM
Lindyp38's Avatar
Lindyp38
Cruising
Default Cylinder head replacement
Driver side has a crack can I just replace the one side of do both need to go ?
Old Aug 19, 2023 | 07:42 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
If your intentions are to keep things stock with the engine and just want to get it running and driving properly, then sourcing one cylinder head is the way to go.....But, since it's apart, I would definitely have both heads (the one good one and the replacement one) gone through (touch-up the valves, check guides, replace seals, check springs, resurface, etc). And don't forget to take your intake with to the machine shop to get checked for straightness as well! This is assuming we're talking about the aluminum cylinder heads for your '93, if this question was asked for the '84 - early '86 cast iron heads, I'd say throw them both in the iron bin....cracked or not!!! Good luck👍
Old Aug 19, 2023 | 08:14 AM
Lindyp38's Avatar
Lindyp38
Cruising
Thank you
i will definitely keep these suggestions in mind
Old Aug 19, 2023 | 09:20 AM
Yonker's Avatar
Yonker
It all depends on the budget.
To Cylinder head replacement
