What line is it
Old Aug 19, 2023 | 12:59 PM
Luthorix's Avatar
Luthorix
6th Gear
Default What line is it
Hello, i started to disassemble my engine bay and as I was removing the bottom metal line on the radiator it snapped. After checking my service codes I don't have an oil cooler and have no idea what its for. I have a 1986 with the 4+3. After looking at a diagram for a 91 with the auto it looks to be a transmission oil cooler line but am unsure and I need to replace it before I take it out for a spin. If anyone happens to know what it is it would be greatly appreciated. I will upload pictures later of the line but on the diagrams for the transmission and cooling it was item# 18. Would the line for an automatic work as it seems to be the same? Thank you
Old Aug 19, 2023 | 02:59 PM
s carter's Avatar
s carter
You need to repair it, it goes to your Over Drive section of your 4+3 if you're unaware you're transmission is a caveman Durable gear box hooked to a temperature sensitive Automatic. So running with it "A" unsealed would pump in dry killed transmission. Sealed /looped back Over heat Killed Transmission so patch it
