Pressure plate and Flywheel
Old Aug 21, 2023 | 12:53 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Pressure plate and Flywheel
Both surfaces of my pressure plate and flywheel look like this:
I was having a noise that sounded like a bad crank bearing and in my process to diagnose I find this. Is this bad enough to require replacing?
I know the stock DMF is not available, what would be the best replacement if I have to?
Old Aug 23, 2023 | 10:29 PM
Gale Banks 80''s Avatar
Gale Banks 80'
That does not look terrible to me and unless you are having clutch issues just re use it. Check out Ram Clutch for what is considered the best replacement. Use the Search here on the forum for lots of info on this topic.
