Fitech 38350 tpi Installed
Old Oct 16, 2025 | 06:09 PM
  #41
Chumbini's Avatar
Chumbini
Originally Posted by MReed
You said if you have a large HEI distributor you need to convert to a small cap w separate coil. On the Fitech 8350 description it says "plus the harness plugs into the factory distributor," So, did you have to convert to a small cap?
yes , I obtained a small cap fir a 1989 iroc. It mentions the small cap in the instructions. It wasn’t difficult, I needed to mount the external coil and wiring
Old Oct 17, 2025 | 03:13 PM
  #42
AZSP33D's Avatar
AZSP33D
Idle issues are tricky with new setups, because it's reacting fast with IAC and Timing changes both trying to catch it, often too quick and too sensitive... and if the timing is advanced too much it may be on the downward side of the curve having the opposite effect... You can see this in datalogs. Alternately, lower the base timing tables to say 14 degrees advance for the whole block up to 1300 rpm or so and check with a timing light. If it still doesn't idle it may jump around a lot but if you hold the throttle fairly steady at say 1000rpm you can confirm timing.
Old Oct 17, 2025 | 04:58 PM
  #43
Chumbini's Avatar
Chumbini
Default First TPI installation
Originally Posted by D Dubya
Thank you, I just did it myself. It was decent out of the box as self learning, but needed some adjustments after the break in. I plan on a gear and pro charger later this year. If that happens I'll take it in for Dyno tuning.
I also installed a FIRST TPI with my FITECH. I replaced a ported Edelbrock high Flo system. The FIRST feels like a different motor. Tons more torque and it pulls in every gear. It’s still in learning mode and I recently converted to a Zf6 so I’m easy on the clutch . Life run it up to 5600 and backed off . The car is a blast to drive. I’m not sure how much HP it has but I’m shocked when I look down at the speedometer and realize how fast it’s going and how quickly it gets there.
Old Nov 8, 2025 | 12:24 PM
  #44
judy marie's Avatar
judy marie
Default my 1985 corvette help
looking for someone with expeirence installing a fitech 38350
Old Nov 24, 2025 | 01:24 PM
  #45
judy marie's Avatar
judy marie
Default 1985 corvette fitech 38350
just finished installing a fitech 38350 fitech on my 1985 corvette so far i am very happy
Old Nov 25, 2025 | 12:09 PM
  #46
Chumbini's Avatar
Chumbini
It gets better the more you drive it
Old Dec 16, 2025 | 11:37 AM
  #47
judy marie's Avatar
judy marie
i had 145 in all 8 cylinders 19 inches vacuum all ign. wires correct timing good nothing wrong with engine did not run right swap over stock 870 ecm to fitech 38350 ecm kit runs great
Old Feb 4, 2026 | 05:20 PM
  #48
judy marie's Avatar
judy marie
can anybody tell me if 1993 lt1 exhaust manifolds will bolt up to my 1985 corvette
