C4 Primary cooling fan
Old Aug 24, 2023 | 11:26 PM
hbermu's Avatar
hbermu
Cruising
Default C4 Primary cooling fan
Hi! Need help with my 1996 C4,,,primary cooling fan not kicking on,,,bypassed it,,,it works,,,,,primary and secondary fans work fine when a/c is on,,,,,checked relays,,,they are good,,,,,,changed cooling fan temperature switch sensor,,,,but when engine is on and temperature is reach and above 226 degrees F,,,nothing happens,,,,,,what I am missing ?
Thank you in advance !
Old Aug 25, 2023 | 11:38 AM
Scott Rasmussen's Avatar
Scott Rasmussen
following, I have the same issue with my 93 except my primary fan doesnt come on when the AC is on either.
