St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Re: Is the TPS adjustable on a 90?? (KYVette90)
Not. It can be "altered" to allow adjustment but I thought I read somewhere that the ECM automatically calibrated the TPS on startup... Not certain about that though. :confused: :confused: :confused:
Re: Is the TPS adjustable on a 90?? (Red 90 L98 Coupe)
That makes sense..... It must be calibrated by the ECM somehow since the engineers went to the trouble to redesign the TPS without adjustment slots, I just can't figure out how it could :confused: :confused: I'll try to find out and let you know
i believe it just take the base voltage and compares that to the WOT voltage to get a percent throttle position. i've heard WOT voltage is as low as anything higher than 3.8, up to anything higher than 4.something.
