1985 C4 headlight upgrade needed
Old Aug 31, 2023 | 12:35 AM
JAR3's Avatar
JAR3
Default 1985 C4 headlight upgrade needed
What upgrades has anyone done to modernize the headlights on their c4? My daughter will be driving it next year and I want her to have great lighting. I found an LED kit for $200 but wasn't sure what else is available.
Old Aug 31, 2023 | 12:44 AM
JAR3's Avatar
JAR3
The kit I was thinking of is from Headlight Experts.
  • H6054 Dual Beam Sealed Beam LED Headlight Conversion Kit
Old Aug 31, 2023 | 09:56 PM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Give this a read👍
https://www.corvetteforum.com/forums...4-drivers.html
Old Aug 31, 2023 | 11:39 PM
SloJo's Avatar
SloJo
I just installed that kit on my 93 and it works great! I would highly recommend it. You won't believe the difference.
Old Sep 1, 2023 | 12:43 AM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Link Link
Plug and play, excellent cutoff, very bright
Old Sep 29, 2023 | 06:01 AM
JAR3's Avatar
JAR3
Curious if anyone has tried the HWSTAR 2022 180W 1000% Bright H6054 5x7 7x6 Led headlights from Amazon? It's $90 and advertises the the same #6054 as the Led kit previously mentioned in this thread.
Old Sep 29, 2023 | 06:04 AM
JAR3's Avatar
JAR3
Originally Posted by flannel_man
Link
not sure how I missed your link but I just asked about this one. Did it cause any codes to come up?
Old Sep 30, 2023 | 04:37 AM
flannel_man
Yeah it caused the "Holy crap I can see the freaking road like it's daylight" codes to pop up 🤣
Otherwise excellent 👍🏻
Old Sep 30, 2023 | 12:49 PM
JAR3's Avatar
JAR3
Awesome, thanks!
Old Dec 18, 2023 | 12:40 PM
JAR3's Avatar
JAR3
Installed and cant believe the difference. Super bright, love the upgrade. Thanks!
Old Dec 18, 2023 | 07:36 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Link
what i use too
Old Dec 19, 2023 | 12:09 AM
flannel_man
Old Dec 19, 2023 | 09:05 AM
yakmastermax's Avatar
yakmastermax
I just installed the following LED headlights from Amazon in my 1989:
HWSTAR 2022 New 180W 1000% Bright H6054 5x7 7x6 Led Headlights Compatible with Jeep Cherokee XJ Wrangler YJ
They went in relatively easy, and after a simple modification to my fog light wiring (I directly grounded the ground wire on each fog light instead of allowing it to run to the high beams, but I think this is only applicable to the 1989 year) everything worked well. I have independent control of my fog lights, low beams, and high beams.
I am VERY happy with the output and pattern. Huge difference. Really makes the car a pleasure to drive. Highly recommend.
Old Dec 20, 2023 | 02:49 PM
1985 Vette's Avatar
1985 Vette
Considering these for my 85 and 88.
Since these are LED's, I suspect these draw less AMPS than the OEM headlights and the existing wiring will be adequate. Is that correct?
I don't quite understand the issue with you having to change the ground on your fog lights.
Update: My OEM lamps are 35/65 watts and these LED's are 180 watts. Thats 3-6X the current draw. I have a FSM and cannot find what amps the "self-setting circuit breaker" is rated for. Is anyone having issues with the circuit breaker in the light switch tripping due to the higher draw of the LED's?
Old Dec 21, 2023 | 03:34 AM
flannel_man
180watt
But they're not... In the world of LED lighting they always like to tell you the equivalent of watts of incandescent ( 180 ) if so then that's 15 amps, needing 14 gauge wire.
No fuses blown yet. What has it been 2 years or more now on mine? Wires haven't melted or overheated
Old Dec 21, 2023 | 10:36 AM
Phobos84's Avatar
Phobos84
The only issue (very small one) that you could have with any of these modern LED headlights is that most of them weigh more than the original bulbs. So you're putting more load on the motors. I really doubt this is an issue but just something to think about.
I just finished the install of the Amazon bulbs mentioned before. They are way brighter than the factory bulbs. I put 35w HIDs in the fog lights also so I should have lots of light now.
Old Sep 13, 2024 | 04:07 PM
borderbyrd72's Avatar
borderbyrd72
A little late to the game but just ordered these from Amazon. Started dailying the C4 and working on making necessary upgrades to bring the car into the current year of tech.
To 1985 C4 headlight upgrade needed
Old Sep 13, 2024 | 06:21 PM
JAR3's Avatar
JAR3
They are amazing headlights.
Old Sep 13, 2024 | 06:52 PM
skorpion317's Avatar
skorpion317
2024 C4 of the Year Winner - Modified
I'm going to give these a shot when they come back in stock:
https://www.fredtechlighting.com/pro...-headlight-kit
The store owner says they should be back in stock in about 2 weeks.
Old May 10, 2025 | 02:06 AM
Pisto9784's Avatar
Pisto9784
1st Gear
https://youtu.be/82AHyfeMH-0?si=tyJV3UriGRZ_iDqA
Any update on how these are ?
