Engine misses under load
Old Sep 1, 2023 | 04:30 PM
Dccowboy0's Avatar
Dccowboy0
1st Gear
Default Engine misses under load
Rarely my 85 corvette will start and idle rough, followed by not responding to throttle unless I have the pedal all the way down, the low and high ends of throttle work but not the middle. It typically happens when I leave work for my lunch break, I have checked or replaced most things in the air system and plan on replacing the fuel filter soon. I have not been able to find a vacuum leak but it is possible. It has new plugs, new plug wires, new iac, new distributor and ignition coil.
