Oil pan removal
Old Jan 21, 2003 | 01:16 PM
his touch's Avatar
his touch
Default Oil pan removal
Manual says to remove left cat. Is this really necessary on a 96 LT1?
Ron
Old Jan 21, 2003 | 02:22 PM
STL94LT1's Avatar
STL94LT1
Default Re: Oil pan removal (his touch)
The left cat doesn't need to be removed on the 96 M6, not sure about the A4.
Old Jan 22, 2003 | 10:22 AM
Tom Piper's Avatar
Tom Piper
I remove the left cat on my '92 LT1 to make it easirer to remove the filter adapter on the block. The filter adapter has to come off to remove the pan.
Tom Piper
Old Jan 22, 2003 | 01:00 PM
his touch's Avatar
his touch
Default Re: Oil pan removal (Tom Piper)
Thanks.
Ron
Old Jan 22, 2003 | 02:26 PM
lead_foot's Avatar
lead_foot
Do the #1 or #2 pistons need to be in any particular position so that the crank throws allow the pan to come off? :)
Old Jan 22, 2003 | 08:47 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Oil pan removal (lead_foot)
On my 88 it does have to be in certain position to take the pan out. By the time you try to take the oil pan out and if it stuck then you can rotate the crank out of the way.
Old Jan 23, 2003 | 07:27 AM
Tom Piper's Avatar
Tom Piper
I remove the motor mount nuts, and raise the engine about an inch instead. This doesn't take long, and makes it much easier.
Tom Piper
Old Jan 23, 2003 | 09:28 AM
VQT88Vette's Avatar
VQT88Vette
Tom Piper
How do you raise the engine an inch using only jack? The only way I can think of your way is with engine lift and chain. That is way too much work just to take the oil pan out.
Old Jan 23, 2003 | 09:40 AM
Tom Piper's Avatar
Tom Piper
Default Re: Oil pan removal (VQT88Vette)
I put a section of 2x8 under the transmission pan and use a large manual scissors jack -- I don't like to use hydraulic jacks in this situation.
If done properly, this doesn't dent the transmission pan.
Tom Piper
Old Jan 23, 2003 | 10:41 AM
lead_foot's Avatar
lead_foot
Where do you jack the engine when the oil pan is being removed? :)
Old Jan 23, 2003 | 11:23 AM
Tom Piper's Avatar
Tom Piper
My previous post assumes that the vehicle has an automatic transmission.
My vehicle has an automatic, and I jack the engine up from under the automatic transmission pan. I've done this several times, and it doesn't cause a problem. Just be careful you don't raise the engine/transmission combination too high that it contacts the transmission tunnel, etc. -- It only takes about one inch for clearance.
For a six speed, I don't know if it will work.
Tom Piper
To Oil pan removal
