Gears and ratios
Old Jan 21, 2003 | 09:17 PM
B84RADR's Avatar
B84RADR
Default Gears and ratios
Hey guys,
Since I have my engine completely out of my '85, if I wanted to change gears, would now be the time to do it? I see several posts about people changing their gears, I'm assuming for more low-end torque.
How do you tell what gears you have in the first place? I didn't put the first 383 in this Corvette and I have no idea if they messed with them at all.
THANKS!
Old Jan 21, 2003 | 09:29 PM
95AquaC4's Avatar
95AquaC4
Default Re: Gears and ratios (sspackman)
Jacking the car up,rotating the rear wheels, and counting the turns of the driveshaft is the easiest way. That should get you close. Your RPO code may help, but since there's already been one replacement engine, chances are there are already good gears in there.
Old Jan 21, 2003 | 11:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Since you are that far along, drop the rear and the original ratio is stamped right on the case. If it's been changed, you can do as posted above.
Old Jan 21, 2003 | 11:19 PM
vader86's Avatar
vader86
Default Re: Gears and ratios (Mr Mojo)
Should be stamped on the casing.
To Gears and ratios
