water pump coupler STUCK!
Old Sep 19, 2023 | 07:31 PM
hotrodln's Avatar
hotrodln
Default water pump coupler STUCK!
OK I screwed up. I put the water pump on with the coupler pointed the wrong way. so the water pump wouldn't seat properly and i took it back off to see what i did wrong...now the coupler is very stuck on there. I tried all my various 2 jaw pullers but i cant get a good grip on it. any advice? does the drive itself just PULL out of the cam gear? i was thinking about pulling the whole shaft out...separating the two then reinstalling it.... Thanks in advance Pat
Old Sep 19, 2023 | 08:19 PM
s carter's Avatar
s carter
I might be a little off beat here have you tried finding a socket and extension that would fit over the top of it and you try to give a little nudge up/down Left Right see if it unjams
Old Sep 19, 2023 | 09:17 PM
hotrodln's Avatar
hotrodln
I tried lots of things that didn't move it.....still thinking of other ways to get it off.
Old Sep 19, 2023 | 09:33 PM
s carter's Avatar
s carter
Well that sucked is totally stuck
Old Sep 19, 2023 | 09:47 PM
hotrodln's Avatar
hotrodln
the snap on guy is stopping by tomorrow...we'll see what tricks he has..
To water pump coupler STUCK!
