Minimum Idle set for ‘85-‘91
Old Sep 20, 2023 | 09:14 PM
Siveck's Avatar
Siveck
Default Minimum Idle set for ‘85-‘91
I recently did this again on my ‘89. Some idle issues after sitting for a few years during grad school. I feel like the blades are too far open and when starting, rpm’s are high for a moment. Idle is a tick high at 8-900 rpm’s. Followed FSM procedure which included disconnecting EST for timing advance. That really made this a struggle. I don’t recall doing that previously with this procedure that is all over the forum. Question:
Should the EST be disconnected for the minimum idle set procedure? Was this revised at some point?
Old Sep 21, 2023 | 08:44 AM
Vets-Vet's Avatar
Vets-Vet
This is what I have. I believe it was from this forum. It worked on mine but mine was not idling wrong. I did this after replacing the IAC and manifold gaskets. It does disconnect the EST timing connector.
Don't forget to turn the car off before going for a test drive because the ECM will not automatically re-establish the advance timing. The below file is windows notepad, let me know if you need the text pasted into the thread.
Here is the thread it was in. https://www.corvetteforum.com/forums...dle-speed.html
Old Sep 21, 2023 | 07:58 PM
Siveck's Avatar
Siveck
Thanks Vets-Vet.
To Minimum Idle set for ‘85-‘91
