the install was very easy on my 92. the rear took all of about 1/2 hour but the front was a little tricky. you have to remove the spring from the car and cut two rubber spacers from the top of the leaf. the hole job took about 3 hours on a lift.
Mid America has all the instructions posted on their web site.....
Pretty much tells all...if you have the energy to do it.....for 3/4" to 1" lowering...to much work to me....although I did buy the kit for the front and rear......waiting to get the courage to do it....
Well anyway Good Luck..
Just go to the site and get the info...
tony
:eek: :eek:
