1988 rough start/idle
Old Sep 28, 2023 | 03:36 PM
1988C4Owner's Avatar
1988C4Owner
Default 1988 rough start/idle
Hello all. Recently got my 88 back together after a head gasket job and she's having a hard time starting and staying running. I did have the initial timing set by pointing the little spindle at cylinder #1 while the engine was at TDC but made the mistake of doing a full crank rotation by hand after I put the cap and all the wires on. If I had to guess I'd say that's a major issue in a hard start. Also, she's basically got no vacuum system whatsoever. She sat in a field in Texas for God only knows how long before I got her so every bit of vacuum line is just about ready to crumble, and most did when I began the teardown. I put all new sensors on (MAF, TPS, IAC, Coolant Temp, Air Temp) but never adjusted the TPS if that plays into it at all. Any help with diagnosing these issues or how to set the timing correctly would be greatly appreciated. I'd also love a vacuum diagram or a way to get one that makes sense and is comprehensive (hose lengths, diameters, valves, and their positions, connectors.) Thanks, everyone!
