Door Locks
Old Oct 2, 2023 | 05:20 PM
CorvetteDoood's Avatar
CorvetteDoood
Cruising
Default Door Locks
Whenever I click my automatic door locks in my 1984 Corvette, you can hear a clicking sound in the center of the dash but nothing happens with the door locks at all? My driver side door panel is off and the actuator moves quite freely with all the other rods.
Old Oct 2, 2023 | 06:01 PM
s carter's Avatar
s carter
Since you have the panel off I put a light on the actuator wires and confirm that all is plugged in.
Old Oct 3, 2023 | 02:11 AM
CorvetteDoood
Cruising
Originally Posted by IHBD
The 84 and 85 power door lock circuitry is unique to these 2 years. The door switches operate a relay in the center dash. The power for the switches to control the relay comes from the CTSY/CLK fuse. The power for the lock actuators comes from the PWR ACCY circuit breaker. This breaker also powers the power seat track and the sport seat functions, if equipped. If the breaker has been removed because of problems with the seats, the power locks won't work either, but the relay will still click.
Check that the PWR ACCY breaker is installed and functional.
Well that would make sense on why my power seats dont work either bruh
Old Oct 3, 2023 | 04:52 PM
7thvet's Avatar
7thvet
Make sure your car starts before you put the door panel back on. Because you may be triggering your alarm which will prevent it from cranking.
It's all tied together with the relay you hear clicking.
To Door Locks
