C4 Headlight gears
Old Oct 3, 2023 | 03:54 PM
engleterry's Avatar
engleterry
Cruising
Default C4 Headlight gears
Replacing the gear in a C4 should you use the Bronze headlight motor gear or use the plastic ones they were from the factory
Thanks Terry
Old Oct 3, 2023 | 03:59 PM
puufgone's Avatar
puufgone
I personally used the bronze gears and all has been good since 1994...
David
Old Oct 3, 2023 | 07:51 PM
engleterry's Avatar
engleterry
Cruising
Thank You I will use the Bronze ones too I was pretty use I should.
Thanks again
Old Oct 4, 2023 | 05:25 PM
Snakecharmer383's Avatar
Snakecharmer383
I replaced mine and used the plastic. Read that the bronze gears were hard on the headlight motor.
Old Oct 4, 2023 | 08:13 PM
SouthernSon's Avatar
SouthernSon
The plastic OEM headlights are easier on the motors. The glass replacements probably should be avoided if you can find the plastic housing lights. I used bronze. Have had the one replacement for years, the other is original and fine for now. I have the plastic lights. Don't know if still available.
Old Oct 4, 2023 | 08:29 PM
sheriffjim's Avatar
sheriffjim
I replaced mine with plastic. It was way cheaper than the bronze, and frankly I don't have money to be throwing around.
My gears failed after I had bought the car. I figure if the original plastic gears worked for 31 years, I don't have anything to worry about.
To C4 Headlight gears
