Pwr accy??
Old Oct 4, 2023 | 11:15 PM
CorvetteDoood's Avatar
CorvetteDoood
Cruising
Default Pwr accy??
Where do I find a replacement PWR ACCY??!?! I don't have one to reference, so I'm quite lost trying to find it on the internet?
CorvetteDoood
Cruising
I have 1984 Corvette for reference.
Old Oct 5, 2023 | 08:26 AM
2011KLR's Avatar
2011KLR
If you don't know what it is or where it is, why do you think you need one? You're leaving out some detail here.
Old Oct 5, 2023 | 08:38 AM
WVZR-1's Avatar
WVZR-1
You're looking for the 'Circuit Breaker'? This post might help you?
***** https://www.corvetteforum.com/forums...post1606854740
Old Oct 5, 2023 | 11:02 AM
CorvetteDoood
Cruising
I need to BUY one. I have an issue with it, and I want to replace it. My seat is grounding out on the frame and it blows the circuit, so my locks etc don’t work.
Old Oct 5, 2023 | 11:53 AM
s carter's Avatar
s carter
If it's blowing odds are you don't have an issue but the cut wire, better/stronger breaker just makes smoke and burnt wires. I will lay odds if you pull out your left seat you will find a rub through. I have repaired a few the seat tracks sliding across chafes the harness
Old Oct 5, 2023 | 08:23 PM
CorvetteRules's Avatar
CorvetteRules
If you are referring to the 30 amp circuit breaker that is not what you should be replacing. You need to determine and repair the dead short. The circuit breaker will trip and reset constantly until you fix the short and most likely getting very hot to the touch because of that. The breaker covers the power seats and power locks.
Old Oct 7, 2023 | 01:29 PM
CorvetteDoood
Cruising
Previous owner removed it and I need to buy a replacement.
Old Oct 7, 2023 | 01:35 PM
s carter's Avatar
s carter
Any parts store just buy right style and amps
To Pwr accy??
