Another no crank problem
Old Oct 5, 2023 | 03:48 PM
pawpaws toy's Avatar
pawpaws toy
Default Another no crank problem
Helping a friend with 1986 with 4+3 trans.
1. Won't crank but can be push started. This would indicate fuel & spark is ok.
2. Clutch switch has been replaced.
3. Have dash and under dash wiring exposed.
4. Have been reading up on VATS system and have downloaded diagrams.
5. My next step is to read restance at key and underneath where the connector is going to the VATS system.
Any insight or suggestions will be appreciated.
Going to start on this Monday.
Old Oct 5, 2023 | 07:58 PM
CorvetteRules's Avatar
CorvetteRules
Have you tested the starter?
Old Oct 5, 2023 | 08:05 PM
pawpaws toy
yes.
Old Oct 5, 2023 | 10:43 PM
dburgjohn's Avatar
dburgjohn
isn't there a relay between key and starter solenoid?
Old Oct 6, 2023 | 12:06 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Yes, the Starter Enable Relay. Behind the DIC.
To Another no crank problem
