High pressure fuel line removal hints needed
Old Oct 18, 2023 | 12:21 AM
dburgjohn's Avatar
dburgjohn
Default High pressure fuel line removal hints needed
I need to remove fuel sender/pump from my 92 LT1. High pressure hose is loose (I can turn it) but can’t pull it off? What is the trick here?
Old Oct 18, 2023 | 01:46 AM
ChumpVette's Avatar
ChumpVette
Just need more leverage. Tight area.
Old Oct 18, 2023 | 08:26 AM
C409's Avatar
C409
Pull harder !
Old Oct 18, 2023 | 01:00 PM
2011KLR's Avatar
2011KLR
https://www.harborfreight.com/3-piec...ers-37909.html
Old Oct 18, 2023 | 07:15 PM
Spencer Smith's Avatar
Spencer Smith
I get a small flat head screwdriver and lightly pry under the edge of the hose to help it release from the inlet.
Old Oct 18, 2023 | 11:48 PM
dburgjohn's Avatar
dburgjohn
already did, I can rotate hose just not pull it off
Old Oct 19, 2023 | 04:15 PM
dburgjohn's Avatar
dburgjohn
I bought these, it pulled hose right off. thanks
Old Oct 19, 2023 | 05:29 PM
383vett's Avatar
383vett
Originally Posted by dburgjohn
I bought these, trying them out this weekend, thanks
What are you going to leverage against to use these tools? As Spencer suggested get a small screwdriver or two and slide it between the hose and the tube. Stretch it out and pull it off.
Old Oct 19, 2023 | 11:17 PM
jv9999's Avatar
jv9999
Heat will help soften the rubber. I'd use a heat gun or even a hair dryer. No open flames of course.
Old Oct 20, 2023 | 08:12 AM
C409's Avatar
C409
Looking at the pic my first thought would be to grab a long square shank screwdriver like a Craftsman and lever it from the bolt head just to the upper left of the hose to the end of the hose to push it off the nipple . And if necessary , use some long needle nose pliers on the hose itself about where the yellow stripe is to the bolt head under it to help pull it off .
Old Oct 20, 2023 | 08:32 AM
Whaleman's Avatar
Whaleman
My 1996 fuel line had never been removed a couple of years ago when I had to replace my fuel pump. I remember it being hard to remove but not SO hard that it required 10 posts on this forum. Once I got it to spin I remember it was 2-3 minutes more until it was off. I put a small thin screwdriver in the hose and levered off at the same time I pulled on the hose with a needlenose plier braced on the filler tube. Dan EDIT: I remember I wrapped electrical tape around the hose where I grabbed it with the needlenose to not hurt the rubber tube.
Old Oct 20, 2023 | 09:19 AM
dburgjohn's Avatar
dburgjohn
Default the answer
I have changed many fuel pumps including a fair share of C4s but this hose seemed to be inhabited by a evil spirit. I could rotate it and get a good grip with long pliers/hand but it would not budge. Until I bought and used the pliers below none of my tricks moved it a bit.
Old Oct 20, 2023 | 01:52 PM
2011KLR's Avatar
2011KLR
HAhahahaaaa!!!!
Old Oct 20, 2023 | 03:44 PM
dburgjohn's Avatar
dburgjohn
No leverage needed. I held in left hand (driver side), gripped hose right at tip of metal bulge, used right hand to stabilize and pushed. Off it came.
To High pressure fuel line removal hints needed
