Headlight Issue 1988 coup
Old Oct 18, 2023 | 07:40 PM
Da Mail Man's Avatar
Da Mail Man
Default Headlight Issue 1988 coup
Greetings all....
1988 vette coup....I have an intermittent issue with my headlights.....IF they are down and I pull the dash **** to turn lights on, sometimes they pop-up and sometimes they don't....Seems the same when switching them off....I can hear the motors click and possibly turning on-off....
I am sure headlight module is ok.....I can turn **** on motor to raise and lower the assembly w/out issue.....***Manually raising/lowering via the motor ****, that is no problem but, let's say that I manually raise or lower the headlight part-way, I can take the headlight assembly and significantly "move" it up and down (raise a bit and lower a bit) as if there was slack in it's travel....
QUESTION:
Should the headlight assembly be "rigid" all the way through it's travel and immovable if I stop it part-way?....IF the 3 "bearings" are worn, etc, would that be a significant contributor to my symptoms?
I have the "bearings" here but, have not gotten 'round to replacing them..(PS: the motors work)...I think that maybe the gear "moved" or a worn bearing is mis-aligning the "innards" (Beverly Hillbillies - ha!)....
Opinions please?...........THANKS.
Old Oct 18, 2023 | 08:46 PM
AffableCurmudgeon's Avatar
AffableCurmudgeon
Just take them out and open up the gear housing. Easier than guessing. You will have to do that to fix them anyway.
Old Oct 18, 2023 | 08:53 PM
Da Mail Man
Well, to be honest with you, I already figured that...Was looking to see (in effect) if anyone else had similar issue.
Old Oct 19, 2023 | 10:39 PM
Da Mail Man
Any other opinions?....
QUESTION:
To Headlight Issue 1988 coup
