Going VATS Sh_t Crazy..( we think )
Last edited by socal714; Oct 23, 2023 at 03:56 PM. Reason: i was told it was kind of confusing to read, i hope i clarified it better
If the car 'CRANKS' with a twist of the 'KEY' you DO NOT HAVE A BATS ISSUE! Your post could maybe use some punctuation and restructuring ..... It's a difficult read!
Like others said, since it does crank, it may not be VATS. However, if your 1986 Corvette previously started with a non-VATS key, then someone installed a VATS bypass/disable. 1986-1991 Corvette VATS ByPass Control Switch (zip-corvette.com). 1986-1989 Corvette VATS Disable Override Module (zip-corvette.com).... Look for these somewhere under the dash. If these were installed, it's possible something is bad or got disconnected from the VATS bypass.
so does it have Fuel pressure 35 PSI+- a simple quick redneck test if you push the test port does it hit ceiling, Does it have Spark, Does it have injector pulse,
If you give it a quick shot of starter fluid or gas does it run for a second or two
True that VATS inhibits starter as well, so if it cranks it shouldn't be VATS, BUT! These cars are 30+ years old now, things may have been changed. Like relays and things have been bypassed and jumpered, and modified.
right. we have seen the starter relay contacts forced together bypassing the control side. Its rare but we have seen it.
Justin
Goof luck.
Goof luck.
**** I can't send you a PM or email but you should be able to do both using links by clicking on my 'user ID'. I can help you with the FSM and others.
Justin
