Hello , We ar etrying to get my 85 4 plus 3 running. New plugs, injectors, fuel filter, fuel pump, blew out the lines and cleaned the tank. Spark plugs are black. Timing is correct. Any ideas? thank you
Are these plugs you just put in and got dirty in a short time, if you have a car that has been inactive with a world of factors like you mentioned I would not be surprised that some fowling could occur plus another factor coming up in second 1/2
or are they something that you pulled and have a horrible build up, if so an 85 possible High mileage extended inactive Engine could have Dried out broken Valve seals and worn Guides.
Also look at O2 sensor could be Tired they are a wear Item
Hey guys these are some great responses. With respect to the injectors they are 24 lbs, stock according to South Bay fuel injection. Purchased in July 2023. I do have a data logging program on my laptop. So we are going to install a set of 22 lbs and run the datalog. We will data log it asap. I did the heads 3 years ago. Oddly enough the plugs got black when I started the car on Guam. Yes, Guam. I want to thnak you all. And, I will update as soon as I now more.
