car starting problem
Old Jan 23, 2003 | 01:39 PM
DADDY D's Avatar
DADDY D
Default car starting problem
In my 86 vette here lately it has been acitng funny. every now and then i will go to the car and it won't start at all doesn't. you can turn the key forward and everything but the car doesn't turn over. Then after awhile you can go to it and it will start just like it is supposed to. what is going on any ideas or similar problems?
Old Jan 23, 2003 | 02:04 PM
brookman's Avatar
brookman
Default Re: car starting problem (DADDY D)
I had this same problem with my 88. It ended up being corroded battery connections. Disconnect the battery cables and pull out the bolts. I have corrosion between the bolt and the metal washer. After I cleaned them and replaced the bolts it hasent happened again
Old Jan 23, 2003 | 07:03 PM
DADDY D's Avatar
DADDY D
i will try that
Old Jan 23, 2003 | 08:12 PM
qkvette's Avatar
qkvette
i have a similar problem with mine. mine would not turn over when i have driven it for about an hour. i thought it was a hot starter issue, and it turns out to be the neutral safety switch. it wasn't allowing enough current to go to the starter solenoid. i created a bypass switch just for the problem, but also putting the gear selector on neutral worked also.
i don't know if yours only act up when it is hot.
good luck.
joel
Old Jan 23, 2003 | 11:35 PM
DADDY D's Avatar
DADDY D
Default Re: car starting problem (qkvette)
it veries from time to time it may be ice cold or it could be when i started drove a mile down the road cut it off and go in the store and come out and it won't start come back a little while later and it starts just like normal and then doesn't do it again for weeks or months or days
Old Jan 24, 2003 | 12:19 AM
Hamert's Avatar
Hamert
The neutral safety switch is a good one to check. Does the starter click at all when it happens? Do the lights dim?
Old Jan 24, 2003 | 12:37 AM
don hall's Avatar
don hall
Default Re: car starting problem (brookman)
..corroded battery connections. Disconnect and clean the connections..
:iagree: It is an easy place to start.
Old Jan 24, 2003 | 01:10 PM
DADDY D's Avatar
DADDY D
Default Re: car starting problem (Hamert)
it doesn't go click at all i am not sure if the lights go dim or not but i don't think they do
Old Jan 24, 2003 | 01:23 PM
John Row's Avatar
John Row
Is there any sound that the starter is engaging? i.e. a click? Clean the battery cables. -- Duh... I should learn to remember what I read...
Does it happen with a different key? If so, clean the keys and maybe shoot some WD40 in the switch.
If you move the shift lever from park to neutral does it start? Back to park?
[Modified by John Row, 12:25 PM 1/24/2003]
Old Jan 24, 2003 | 08:19 PM
DADDY D's Avatar
DADDY D
Default Re: car starting problem (John Row)
it makes no sound of any sort. i will try to clean the battery cables tomorrow i went out tonight about 6pm and started it and let it run for a while and cut it off try to start it right back and it would not start at all i probably could go out there now and it start right up
Old Jan 25, 2003 | 04:31 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Of course do as the others have said with regards to cleaning and checking battery cables and connections, but this really sounds like VATS especially on an '86.
http://www.corvetteforum.net/c4/rayquayle/vats/vats.htm
Old Jan 25, 2003 | 09:35 AM
Corvette_116's Avatar
Corvette_116
Starter could be on its way out. Could try the old bang and clang method. Next time it doesnt start, try tappin on the starter with a bar and have someone crank it while you are tapping. BE CAREFUL.
If she engages while you are tapping, then new starter is required.
Old Jan 25, 2003 | 01:56 PM
JIMBO7's Avatar
JIMBO7
Default Re: car starting problem (Corvette_116)
I had the same problem and it was hard to find. Garage could never locate it.
I found a loose connection at the alternator. I soldered it when I got home and I never had the problem again.!! :D hope you find it!
Old Jan 26, 2003 | 01:16 AM
jfb's Avatar
jfb
If it still does it after cleaning the battery cables and battery posts, it could be VATS or the clutch safety switch. When it won't crank, jump the clutch sw and try a crank. If its VATS, you won't hear the click from behind the center of the dash in crank position, this is the VATS enable relay. First try your spare ign key as its pellet contacts are not worn like your everyday key. If no crank, then find the 2 pin connector under the carpet by the steering column, this is the contacts in the ign sw that make with the pellet. Unplug and put an ohmeter on the wires from the column and insert your ign key. The ohmeter should read the same resistance as the pellet. If over 10k, you need a new ign sw as the pellet contacts are worn. You can clip a fixed resistor the same value as your pellet onto the wires going to the passenger side (VATS module) and fool your VATS into thinking the correct key is in the ign. Don't permanently defeat VATS because 99% of thefts are done by bashing the column, jumping the ignition and your C4 is theirs.
Old Jan 27, 2003 | 01:04 PM
DADDY D's Avatar
DADDY D
thanks for all your help come to find out it was the starter which i had changed about six months ago but put a new one on and it fires right once again thanks for your tips
To car starting problem
