RPM revving
Old Nov 3, 2023 | 07:19 PM
VETTEMASTERZ51's Avatar
VETTEMASTERZ51
Default RPM revving
My 1990 C4 starts and idles just fine at around 3-4K, When I give her throttle, it jumps up and over 8K. Is the RPM needle stuck?
It doesn't sound like its revving loud. Any thoughts?
Old Nov 3, 2023 | 07:23 PM
Topduarte's Avatar
Topduarte
Sticky needle or something with gauge board is acting up.
Old Nov 3, 2023 | 07:45 PM
ChumpVette's Avatar
ChumpVette
Tach in the 90-96 have issues and will be off. You can repair yourself or send to Batee for repair or buy a used one and hope it works.
Old Nov 3, 2023 | 08:56 PM
Spencer Smith's Avatar
Spencer Smith
You can also buy the resistor from Batee and solder in yourself. Fairly straightforward job.
Old Nov 3, 2023 | 10:11 PM
s carter's Avatar
s carter
This could be the as mentioned
https://corvetteparts.com/item/filte...ment-1975-1991
To RPM revving
