88 Corvette belt close to frame
Old Nov 14, 2023 | 09:34 PM
SynthwaveVette's Avatar
SynthwaveVette
Default 88 Corvette belt close to frame
I just picked up this 49,000 mile C4, and I noticed that the belt and pulley seem awful close to the frame. Is this normal or something I should be concerned about?
Old Nov 14, 2023 | 10:57 PM
drive it's Avatar
drive it
If it has the original motor mounts they have probably sagged quite a bit. I replaced with hew poly mounts and it took it up an easy 1/4 inch+.
Old Nov 15, 2023 | 08:49 AM
FostersPerformance's Avatar
FostersPerformance
Old Nov 15, 2023 | 11:44 AM
puufgone's Avatar
puufgone
Yeah, getting your belt tensioner pully bolt out will be a real pain too with saggy motor mounts...ask me how I know...
David
Old Nov 16, 2023 | 07:50 AM
SynthwaveVette
By the way, do you know any good videos or guides to replacing the motor mounts? I'm sorta new to owning a Vette and cars in general lol. From what I've seen it looks like quite a task though.
Old Nov 16, 2023 | 08:51 AM
FostersPerformance
Just did mine with poly a year ago. I did do a small write up about it. Fairly easy. Support engine from top with hoist, remove long frame bolts then motor mounts. Biggest PITA is WHEN you drop a bolt, it goes right into the k member and is a pain to retrieve. Get a decent small magnet tool and also one of those finger magnets - they work.
To 88 Corvette belt close to frame
