Plugging Brake Line???
I need to replace a steel braided brake hose but didn’t want the fluid to all leak out & create another problem with the master cylinder or abs system. So how can I plug the line so it stops bleeding where it connects to the steel line while I drive across town & take the old flexible line with me?
(89 Corvette front right hose)
Do you mean you're wanting to plug this line and drive the car or would you be taking a different vehicle and just need to stop the flow while the car is sitting there?
If it is A, then I'd say don't even try it.
If it is B, then most anything would stop the fluid from dripping out. It isn't under pressure while it is sitting there. Duct Tape it
sre
sre
sre
sre
Please do everyone a favor & go play on the freeway!
Like this.
Or this.
Such hostility for no reason.
Zip tie a ziploc baggie on it.
Do whatever you like. You're overthinking it anyways.
Enjoy your day.
Enjoy your day.
CorvetteRules (12-06-2023)
The following 2 users liked this post by VikingTrad3r:
CorvetteRules (12-06-2023),
Incorvettei (12-06-2023)
I didn't think ahead one time and used a regular wood pencil lol yes it was just the right size and stayed in.
It won't drip our that much in a short time. Make sure your reservoir is full and just let it drip. I've let mine drip overnight before and it didn't drain the reservoir even half way. It's only if you run out of fluid does it put air into the master cylinder.
