[tech] '90 oil temp sensor?
Old Jan 24, 2003 | 05:52 PM
eddieL98's Avatar
eddieL98
Default [tech] '90 oil temp sensor?
ok i looked through the archives and wasn't sure on a part number. anyone know what the part number for the temp sensor on a "90 is. it's located under the distributor area. there are two sensors there. the oil pressure and the temp. had the temp gauge leak like crazy, spewing oil everywhere making a mess. i didn't have a part number so i just installed an oil pressure sensor in it's place. i went to pepboys and autozone and no one could tell me what the part number was, they looked at me like i had 9 heads. i tried using the numbers on the sensor at gmparts.com but no luck. can anyone help?
Old Jan 24, 2003 | 05:57 PM
gtsyellow's Avatar
gtsyellow
Default Re: [tech] '90 oil temp sensor? (eddieL98)
call your dealer, ask for parts, they will get the number in minutes. they have diagrams of exactly where it is and the part number. just get it from a local dealer. mine was under $30 if i remember right, basically your down the street dealer will sell for similar to online.
Old Jan 24, 2003 | 06:06 PM
pablocruise's Avatar
pablocruise
really? I did not know that. (my 89's is located near the oil filter/engine ground area)
I learned sumpin' new today :thumbs:
Old Jan 24, 2003 | 06:37 PM
gtsyellow's Avatar
gtsyellow
Default Re: [tech] '90 oil temp sensor? (89 Paul in Cal)
that's the pressure sending unit, or should be anyway, temp is on the rear of the engine by the dist.
Old Jan 24, 2003 | 06:57 PM
Vic'89's Avatar
Vic'89
Default Re: [tech] '90 oil temp sensor? (gtsyellow)
I believe you have it backwards.
Vic
Old Jan 24, 2003 | 06:58 PM
mash557's Avatar
mash557
Is it different on the later L98's. My 86 has an oil pressure switch for the fuel pump and oil pressure sender by the distributor. The oil temp is down just above the oil filter. Have replaced the pressure sender.
Old Jan 24, 2003 | 07:24 PM
gtsyellow's Avatar
gtsyellow
Default Re: [tech] '90 oil temp sensor? (mash557)
i could be backwards, i know the switch is by the distributor, the temp could be by the filter and pressure by the switch. can't remember, just know i ordered all 3 with the new engine and put them in the respective holes.
Old Jan 24, 2003 | 08:23 PM
eddieL98's Avatar
eddieL98
{correction} it was the oil pressure switch. :banghead: guess we have two diffrent types? who knew. thanks guys for clearing up all the confusion. :auto:
[Modified by eddieL98, 3:10 PM 1/25/2003]
Old Jan 24, 2003 | 09:36 PM
dlmeyers's Avatar
dlmeyers
Page 6A1-3, Figure 1, Factory Service Manual, Corvette 1990.
Item 49, Sensor, Oil Temperature, located above and slightly to the right of the oil filter.
Item 28 and 45 located by the distributor are shown as Switch, Oil Pressure and Sensor, Oil Pressure respectively.
Not sure about other years.
dlmeyers 90 coupe zf6 3 speed shocks
Old Jan 25, 2003 | 04:50 AM
ToniH's Avatar
ToniH
Default Re: [tech] '90 oil temp sensor? (dlmeyers)
This is the way they are in '91 too. Oil temp sensor is close to the oil filter.
Toni
To [tech] '90 oil temp sensor?
