Brake lights staying on?
Old Dec 12, 2023 | 05:15 PM
StanJarensky's Avatar
StanJarensky
Default Brake lights staying on?
Hey everyone,
I just got done replacing my brake booster in my 1994 ZF6 LT1. I haven't put everything back together yet, but I noticed that the brake lights are staying on unless I disconnect the battery. I'm assuming there's a brake pedal switch or something I must've grounded or something, but it's a bit of a nest up there. What exactly am I looking for?
Old Dec 12, 2023 | 05:19 PM
1Hotrodz's Avatar
1Hotrodz
There should be a momentary push button or switch that makes contact with the arm of the brake pedal.
Old Dec 12, 2023 | 06:37 PM
s carter's Avatar
s carter
This is a common side effect as above said there is a contract switch by brake pivot, it's a white plunge type switch all you need to do is push down pedal and reseat the switch against the brake arm after that it will self adjust
To Brake lights staying on?
