Bent Nose
Old Dec 18, 2023 | 09:04 AM
Damon 86' Auto C4's Avatar
Damon 86' Auto C4
Default Bent Nose
I have a bent nose going up and it rubs the hood. When I step on it goes down. Someone hit something to bend it. Is there a hack where I can bolt it to a chain on the floor and jack the car up to bend it back. Sound like it will not work, but it went down with little pressure.
Old Dec 18, 2023 | 11:23 AM
FostersPerformance's Avatar
FostersPerformance
There isn't much to adjusting it correctly. Search the forum and you'll see how to do it, or youtube.
Old Dec 19, 2023 | 09:19 AM
Damon 86' Auto C4
suer thing, good advice, keep looking.
Old Dec 28, 2023 | 11:29 AM
Damon 86' Auto C4
It is bent, not out of adjustment. No way of adjusting. I had room enough to trim nose to a perfect gap. I need to paint anyway.
Old Dec 28, 2023 | 01:42 PM
FostersPerformance
The bumper itself was bent?
Old Dec 28, 2023 | 04:44 PM
AZSP33D's Avatar
AZSP33D
Did you loosen the two bolts on each side of the subframe (under steering rack)? Although i really have little if any idea about what you're referring to as a bent nose, perhaps explain.
To Bent Nose
