1987 4+3 Bleeding Questions
Old Dec 19, 2023 | 06:04 PM
JulianWantsACorvette's Avatar
Default 1987 4+3 Bleeding Questions
Good evening, i just bought an 87 Corvette and I'm running through the maintenance to get it back on the road. My Dot 3 brake fluid for my clutch pedal is a dark grey. I need to bleed the clutch but was wondering if that is all I need to do. Should I completely drain the fluid and start new?
Old Dec 19, 2023 | 08:19 PM
s carter's Avatar
s carter
Remove the fluid out of the reservoir and wipe it out leave a little in the opening so you don't get air in the system refill, then go below with help from a friends foot or a bleeding tool Harbor Freight has a nice cheap one that has attachment to keep reservoir full and drags out of bleeder.
​​​​​​ You may while your bleeding you may want to push the piston in and push some nasty out
