setting adjusting valve lash after a re seal
Old Jan 19, 2024 | 07:23 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default setting adjusting valve lash after a re seal
Question.
Currently tearing down an engine, to get the heads inspected, do a valve grind, vss, and reseal etc.
When i get to the valve lash…
Can i run my old distributor that i made into an oil pump primer….to pump ip the system so that oil is coming out of all the pushrods….and then do this:
(my question is really should i pressurize the system with my dizzy turned oil pump primer)
method i use, from @Joe C
for the adjusting sequence and method,
follow the FSM - that basic method's been working since 1955, and widely used at the factory during the engines initial assembly. as follows --
with the engine in the #1 TDC (compression), adjust the following:
exhaust -- 1, 3, 4, 8
intake -- 1, 2, 5, 7
(this is my personal method) instead of "rotate the push rod while turning the adjusting nut," I use a .0015" feeler gauge, between the rocker arm and valve stem, slowly tighten the adjusting nut until the feeler gauge "grabs." [i add oil to the feeler gauge so i can really feel the “grab”] at that point, you should be within .001" of zero lash. then adjust the nut 3/4 turn. this method seems a little more exact or precise than the "rotate the push rod" method, which IMO is a little too subjective. this should result in a more even adjustment across the board. either method will, however, work just fine.
now, rotate the crank 1 revolution or 360° and adjust the following:
exhaust -- 2, 5, 6, 7
intake -- 3, 4, 6, 8
Old Jan 19, 2024 | 09:30 PM
Joe C's Avatar
Joe C
-- glad to see someone is making good out of my technique. nothing special as it was pure desperation one day when i continually kept getting #1 intake too tight. can't remember when i started it, but I'm thinking it's been some 20 years now.
Old Jan 20, 2024 | 06:21 PM
84 4+3's Avatar
84 4+3
I've done them in a similar manner... you do have quite a bit of wiggle room on the lifter preload... it'll run fine with a quarter or even a little over 1 turn of preload in most cases. I just lift up and down on the pushrod until I don't feel it moving then set preload. Feeler gauge is a little more precise. I've gone back and checked running and they're all usually dead on.
Old Jan 20, 2024 | 07:17 PM
VikingTrad3r
Oil Producer
Thanks for the replies.
So do i pre-prime the oil system prior to doing lash or no?
Old Jan 20, 2024 | 07:54 PM
84 4+3's Avatar
84 4+3
As long as the plungers are fully extended it shouldn't matter but couldn't hurt to prime it in my opinion.
Old Jan 21, 2024 | 12:13 AM
VikingTrad3r
Oil Producer
are the plungers the center portion?
Old Jan 21, 2024 | 08:05 AM
84 4+3's Avatar
84 4+3
Yes
Old Jan 22, 2024 | 08:28 AM
RichS's Avatar
RichS
It's easier to feel zero last with them pumped up. So I prime the system before setting lash.
Old Jan 22, 2024 | 10:21 AM
VikingTrad3r
Oil Producer
Yes
As always, thnx for the help!
perfect this is what i will do. i read that u need to use an old dizzy because without it certain passages do not get pressurized. so i sacrificed an old dizzy years ago.
your system worked fantastic for me on my first valve lash adjustment many years ago and ive kept it handy ever since! The only modification i did was to put an oil film on my feeler gauge as it becomes very easy to feel the “bite”. cheers!
Thanks all!
To setting adjusting valve lash after a re seal
