LS Swap Documentation
Old Jan 22, 2024 | 09:34 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Default LS Swap Documentation
Hi guys! I am swapping a 6.0 truck engine into an 89. I know it’s been done before so that part is no big deal. Because I have neuropathy in my feet I have to also switch to an automatic. I have always loved the C-2/3/4/5 generations the most. This time it will be an 89. My intention is to swap out the packman dash to analog gauges. For now the trans will be a built 700R4. Why? because I already have one. So I am looking for input. If you have done this and went along with what I’m doing or decided to do a different way your thoughts are welcome. If you see in future posts something I have not considered or something I could do differently chime in. I hope to document (with photos) this build as I go along to help the next guy along. THE CAR: It’s a 1989 Coupe that was in a fresh water flood so for now it’s a roller the ZF was locked up and so was the engine they are gone. The interior was stripped out. It’s been in storage as I haven’t been able to get it in my barn, I will be soon moving it inside. As you can see it’s early in the process.(end for now).
Old Jan 22, 2024 | 10:32 AM
Phobos84's Avatar
Phobos84
So I'll play devil's advocate here. I've had two different transmissions with two different LS engines in my 84. I started with a 4L60e and now have a 4L80e. I know you already have a 700r4. But if it were me I would sell it. If it's built you could probably get a lot for it. Sell it and go pull a nice low mileage 4L80e out of a 3/4 or 1 ton Express van. You will need a new driveshaft but for the 700r4 you needed one anyway. Then no TV cable and a way stronger foundation. If you trash the thing you can go get another one for $200 from most any u pull it salvage yard. With a smaller billet converter the weight difference between a 4L80e and a 4L60e is only 20 pounds.
I went with aftermarket gauges in mine. One thing to be mindful of is what ECU are you going to use. This plays a roll in gauge selection. I used a Holley Terminator X max. The gauge outputs from that ECU are a negative pulse (NPN) only. Most aftermarket gauges can't read that signal. So I had to use either pull-up resisters or transistors to convert the signal to a positive (PNP) signal. Not a huge deal just annoying.
For a driveshaft the best shop I have ever dealt with was Action Machine. Their head machinist is a guy named Bob Guzman. His work is incredible and their prices are very good. I up sized my driveshaft to a 1350 yoke with steel and upped the tube size a bit and that shaft was only $250. I had him make me steel half shafts also.
Will a 700r4 work with an LS....yes. but it will go a lot smoother if you sold it along with your pac man gauges and get something computer controlled and go that route. But that's just my opinion.
Old Jan 28, 2024 | 01:46 PM
87bob's Avatar
87bob
Ok I like what you said I got a 4L60 core for 200.00 and I have the four bolt tail shaft housing to fit the support channel. But the 4L60 has a six bolt end on it? Did they do a four bolt tail? how do I connect the support beam?
Old Jan 28, 2024 | 03:02 PM
Phobos84's Avatar
Phobos84
You fab an adapter. You need a 4 1/2" chunk of box steel that's around 1/4" thick and around 12" long. You'll also need some 1" bar stock around 1/4" thick. I've made two of these now. One for the 4l60e and the one that's in the car now for the 4l80e. I take the transmission and bolt it to an engine stand and start test fitting. If you do a search there are a couple different versions that people made and posted threads about how they did it. It just takes a little creativity and a welder. Total cost is under $100.00 in steel. I ordered the box steel online and I already had the bar stock. 4 1/2" box is a goofy size so you might have to hunt to find it.
After re reading your post I was mistaken on something. Going from a manual to an auto you wouldn't need a new driveshaft. The factory one you have would fit with either a 700r4 or a 4l60e. You would need a shorter one for a 4l80e.
​​​​edit....In case you're interested I found the old thread I made back when I made my 4l80e c beam adapter. The search on the forum seems messed up. I had to find it using Google.
https://www.corvetteforum.com/forums...dana-44-a.html
To LS Swap Documentation
